Streekg, did you have to use the Adjustable cam gear to get the idle correct? Or could I reuse the stock cam gears? I want more power, but I am looking for a mild street use experience, where the car is smooth at idle and less 65mph cruise speeds but WA HOOOO AT 3000+RPM?
I have adjustable cam gears installed also.
You can get the idle correct but you will also have an engine running very rich also.
If you are serious about Feind cams, the essential things you need to have a nice running car are.
Upgraded torque converter, i installed mine recently and the car became much more driveable, highly recommended.
Also a system like the FrankenCIS. Mine is almost installed. This allows for a very broad range of tuning and also laptop tuneable. Without this, or a complete EFI swap, you are extremely limited to tuning.
