W111 Coupe
Hi all,
could someone tell me what is the diametre of the 560 front brake rotors?
Thanks in advance
'82 380 SL, '82 300TD, '85 500SEC
Sorry I don't have the dimensions in millimeters at hand, but generally the rotors are referred to as 11" or 12"...in the '86/87 timeframe the rotors were enlarged and the calipers changed to accomodate. Dave
W111 Coupe
Thanks. Assuming an inch is 2.5 cm the diametre of the 12" must be 300mm, as on E500s.
I am trying to see if I can fit E500 4 pistons calipers on a 560. But I came to understand that E500 rotors are not vented (this is weird) so the E500 caliper may not be able to accomodate the thickness of the 560 rotors. Plus I don't know if the caliper fixing points would match...
