1965 W111 220S, 1968 W108 280S, 1970 W108 280SE, 1990 W126 500 SE, 1992 R129 500SL & 1995 E320 S124
Hey there guys,
I have a 1990 500se and ever since I've taken delivery, which is now a couple of months ago, I have felt that the car is not performing the way it should. Don't misunderstand me, I fully understand that this is no street racer! I have tried checking the ignition timing and have come to understand that it is set electronically. I have changed the EZL (sourced from a 560) due to the original failing, but still the performance is not what I expected. I base my conclusion on the fact that I drove other 500's before I bought this one and they went like hell compared to my current car. It seems to be sluggish and has a 'flat spot' when you accelerate hard from standstill. Is there any way that I can check the ignition timing and more importantly adjust it? What do you suggest/recommend I check to improve the situation?
The fuel economy has gone for a ball of s.... of late and I don't know why, as I had it serviced less than a 1000km ago... I must add that I don't trust the mechanic who did the work all that much, although he came recommended.
I would appreciate your inputs.
By the way just to be sure, my car is fitted with the 117.965 motor (I believe?)
Thanks and regards,
H
Thanks and regards,
H
