That`s something I never knew :thumbsup:Should be pretty much a straight swap, but you'll need to use the front seat bases from the 300E, as the V8 bases are narrower.
Is that because the transmission tunnel is wider on the V8s? Is the seat base the same size on a 400e and a 500e?Should be pretty much a straight swap, but you'll need to use the front seat bases from the 300E, as the V8 bases are narrower.
