On my 1996 S500 Coupe, I've had the dreaded vibration, I haven't found a comprehensive list of issues to check so I'm trying to compile one of the things I should check with a mechanic friend.
Anything I should add to this list or caveats?
Also, is 150Nm the torque spec for the wheel bolts?
Draft list:
Draft list:
- Check all suspension bushings for damage (tie rods, upper/lower control arms, etc.,) - this is often from the lower control arm bushings but could be other components
- Check front and rear flexdisks - the front flex likely has worn out more
- Check the long “shaft mount” and “shaft bearing” - may be called the “center support bearing”
- Do not use airtools for installing bolts unless using a torque limiter/meter ... install bolts in torque sequence using a torque wrench
- Star crossed torquing is very critical because the stock rims have a very big center bore and lug bolt holes
- Tires might have flat spots from sitting
- Road force balance
