Will be changing the 4spd manual transmission fluid for the first time? What all i should order and anything i should also change related to transmission while changing the fluid; so i can order it.
And just curious I was thinking about using the MOPAR NV4500 SYNTHETIC MANUAL TRANSMISSION FLUID or should i stay away from it. Or use Mobil 1 ATF synthetic or something...?
Any other recommended fluid i should get?
