Let me back up here a little bit. Whole control arm replacement is expensive (parts), and very hard (require subframe dissassembly). See the service manual pages for the front lower control arm replacement attached to this post.
The outer bushing is not sold separately at the dealership. The part number is A2113331914.
Other part numbers are:
SWAG 10 92 1540
FEBI BILSTEIN 21540
AYWIPARTS AW1420044
LYNXauto C8432
MAPCO 37875
MEYLE 014 033 0091
LEMFÖRDER 2604401
MOOG ME-SB-2730
I decided to go wtih the "LEMFÖRDER 2604401". They are available on eEuroparts as well as FCPEuro and very cheap ($8 each).
I had an initial attempt at replacing the bushings (please see my post https://www.benzworld.org/forums/17721884-post8.html) and I could not figure out how I could move the strut out of the way to gain access to the bushings!
@amosfella suggested that I could remove the three nuts holding the strut from the top (https://www.benzworld.org/forums/17722232-post9.html).
I had another idea that I thought I would try first, which was to compress the coil over spring so the strut lower end can be lifted up to gain access to the bushings (check the pictures below). Unfortunately, this did not work.
SWAG 10 92 1540
FEBI BILSTEIN 21540
AYWIPARTS AW1420044
LYNXauto C8432
MAPCO 37875
MEYLE 014 033 0091
LEMFÖRDER 2604401
MOOG ME-SB-2730
