1 - 10 of 10 Posts
Immoderately Caffeinated/ Vintage Moderator
T5
Drop a post in the 450 rag top forum. When they go like that the plastic has usually oxidized all the way thru and the best thing is to get a trimmer to sew in new windows. You'll have to find out the best material if the trimmer doesn't know.
1999 E320 - 2012 Porsche Cayman
You could try plastic polish the kind they use on airplane windows but that one looks a little too far gone replacing may be your only option
1974 450SL, previously 1986 420SEL
mine was that bad or worse. I used Meguire's PlastX
1972 350 SL
wow! mine looks exactly like both of the examples here and I’m not getting a new top for a while so I’ll give it a shot.
Try it and let us know (pix or it didn't happen). I think I used Plexus after the Meguire's product as a final polish/protectant. And I repeated the process a few years later just to keep it fresh.
1972 350 SL
Here is a before pic and i’ll post after pics either tomorrow or Sunday depending on when Amazon delivers that PlastX. I have no faith in getting the very dark areas clean but the yellowing might and that would help my site a lot so it’s worth it.
1972 350 SL
well it helped a ton with the foggyness but the yellowing and dark spots not as much. Still totally worth it and when I replace the softop I’ll use plastx probably once a year to revive it. I also waited too long to take the photo and it’s at dusk instead of full daylight so that’s not helping
Hmm, maybe try again or polish longer. I was able to get all the yellow off of my window with PlastX (and a microfiber towel IIRC). You do have to do a refresh from time to time.
1 - 10 of 10 Posts
