After owning my first MB for three weeks, I finally drove it! During the 5 miles I put on the beast, I noticed a regular "brushing" sound. Looking through the many books I've collected I think I may have found an avenue to investigate. I think I've got one of three possible problems. 1 a dry center bearing 2 Bad u-joints or, 3. Flex coupler problems at either or both ends of the shaft. I've read the write-up on this forum regarding the procedure to pull the shaft and have a couple of questions.
The 46mm wrench used to loosen the bolt at the front of the shaft, should I use a box/open wrench or a socket? My Chilton's manual shows two wrenched used together to loosen it, should I buy two wrenches or use the chain wrench mentioned on the forum?
Thanks for your wisdom oh great gurus of MB-land.
