1 - 16 of 16 Posts
1973 350SLC :1964 MGB :1966 390 Galaxie :1964 EH Wagon
Pretty easy to make a classic look silly... why not just checker plate the side as well
1980 450SL & 1988 560SL
Old car would look OK with different wheels and maybe loose the red grill.
'80 500SE AMG '80 300SD '78 450SLC '00 Passat GLX Wagon
Throw a nice set of BBS and a new grill on there and that car would be okay. I'm pretty sure it's been posted here before. No surprise who the hell would want it the way it is.
560SL,380SL
Other than the wheels and the steering wheel being on the wrong side(!), it seems like a pretty good car - and he did offer to knock off the wheels. But those wheels! Why do people do this?
1987 560SL
I'm still not a fan of the ground effects kit on the back. It doesn't look right for the car.
1978 280slc
I saw an older continental with 22s on it the other day, the thing would barely turn, you could hear the tires rubbing the fenders.
Nah... steering wheel's fine where it is...
500SLC #2624. Black on Black.
Damn those crazy Australians!
He's been trying to sell it for a while.
The car has one thing going for it, he's put an alloy M117 5litre engine in there.
MBZ '87 300SDL, MBZ '85 380SL, RR '77 Silver Shadow II, MBZ '98 E300TD
That is some donk!
10" width too wide for the front, unless you use crazy thickness on hub-centric spacers and those are probably too long to avoid having wheels poking out both sides. If you have to match that in the rear, you'll have to pull the wheel wells out and that requires a bit of specialist metal banging to do properly. 8.5" front is about as wide as you want to go with relatively slim/high quality H&R or similar TUV approved spacers and longer, similarly high quality bolts. Personally, I don't care for the wheels, but whatever floats your boat.
1 - 16 of 16 Posts
