1 - 1 of 1 Posts
1987 420SEL 220k mi.
I recently had a dome light that came on for no reason at all. It drove me up a wall. Finally I found the cause. The trunk light switch wires go thru a tubular hinge on the driver side. After years of chafing, the insulation finally wore thru and caused a dead short(occasionly). This also caused the #15 fuse to blow, knocking out the auto antenna, rear courtesy light, and power door locks. If anyone has this kind of problem, check that wire. Thanks for all who tried to help. Don
1 - 1 of 1 Posts
