ok so I posted the Mog nightmare post and it turned out thankfully to not be a blown motor but instead the fan hitting the pulley. So I think we have isolated the problem to be the rubber underneith the metal fan that it turns on is coming loose. The piece I'm referring to is kind of like the harmonic balancer from what I'm told.
Well I pulled the radiator and took out the 6 bolts holding on the Fan, but I can't get it off!
To get the fan off do you need to remove the big 1 3/4" nut in the center of the fan? I tried to get that sucker loose and boy is it tight. I had to hold the fan with a crow bar and it started bending the fan blade so I stopped.
Where am I going wrong?
Should I just shave some metal off the fan blade to give it some clearance so that it doesn't hit the pulley? I think this would be a temporary solution that would work for at least a year or so, what do you think?
