1 - 20 of 56 Posts
85' U1300L Holset Turbo VA A/C, 66' Propane 404.1 rock mog, 1975 416 Doka, G500, Volvo C303
Ok, I should probably find a German forum to ask these questions, but here we are.
My 411C came with some convincing Lucas L713 tail lights. Now I need some eubber Grommets for the mounting hardware and when I saw they were Lucas I paused and thought maybe these are not stock. So I’m here to ask the collective if these are right or if I need to source new lights all together.
Automotive lighting Automotive tail & brake light Purple Amber Violet
This is what mine came with. They attach to the back of the bed with plates cut to the same shape.
U1450L DOKA
I took a look, and I didn’t see any that matched your taillights.
The Amber / Red combo is frequently seen, but a lot of them look like aftermarket stuff.
I did notice an Oval version, Red and Amber, that appeared often on what I’d call Museum Quality restorations. They are small, and looked believably original.
I went to Mogparts ( an excellent suggestion), and Bingo - the Oval lamps appear with the ‘OEM’ tag on the listing.
I think that seals it, but it depends on the year.
Many 411’s have the rectangular Hellas that also appear on the 403 -406- 416-SBU’s, Etc. UNIMOGs. I believe that they are probably correct for the later 411’s.
Again, Mogparts would know, I reckon.
Brown Plant Font Material property Recipe
U1450L DOKA
Yours might be an original upgrade for 411 snowblowers, something that Schmidt went with for better visibility in winter conditions.
When I get a chance, I can scroll through the 411 Snow Cutter files, and check the black and white vintage files as well.
U1450L DOKA
OK, I looked through a pretty good-sized wad of photos, and I can report :
A. I did not find any that matched yours, so far.
B. The Early 411's at least, looked to have the small oval bi-color lamps.
C. I did not find anything like yours on 411 Snow cutters, although some larger round lamps are seen, as are the common rectangular Hellas.
D.I did not go into the Frogeye or Westfalia files, I just stuck with the 'Door Stop' open 411's.
E. The Swiss did not use the small ovals on their Swiss Army 2010's - they upgraded to a slightly larger round lamp. I did not go through every 2010 file, but enough to see the trend.
F. The Ovals are authentic, and they are small - they tend to disappear in photos as they are tucked up under the bed.
G. There are Rights and Lefts on the Oval lamps - the Left side has the clear lens on the bottom to illuminate the license plate.
H. I think that the later 411's moved away from the ovals to the rectangular Hellas. I did not do any research on this - I'm just guessing that is the case, based solely on staring at photos for a while. They might have moved to a larger bi-color Round lamp in between the two, again, just based on looking at photos and seeing the round lamps on nicely restored 411's.
Both Mogparts and MogWorld show the lamps - Note the Hella logo on the lens.
Tire Wheel Vehicle Automotive tire Motor vehicle
Wheel Tire Vehicle Automotive tire Motor vehicle
Tire Wheel Vehicle Truck Automotive tire
Tire Wheel Vehicle Motor vehicle Automotive tire
Wheel Tire Sky Automotive tire Vehicle
Plant Flower Tire Vehicle Wheel
Tire Wheel Vehicle Car Automotive tire
Automotive parking light Automotive tail & brake light Automotive lighting Amber Automotive design
Automotive tail & brake light Automotive parking light Automotive lighting Automotive design Gas
Wheel Vehicle Motor vehicle Plant Tire
U1450L DOKA
OK, Hold the Dang Phone...
I found one photo of a 411 Schmidt snow cutter with what looks to be a good match for your lamps. This would change things, if true, and put the lamps you have into the OEM category.
Probably - Maybe.
The photo of the 411 isn't the greatest, but there is one detail that has me fairly convinced. The shape is similar, and maybe you can confirm if the scale is right, since you have a lamp and the bed to compare it to. The thing that got me is the Red horizontal reflective band that separates the top Amber portion from the lower Red part. The Band is quite clear in the photo of the 411.
So, maybe SCHMIDT did tap into the products of 'The Prince of Darkness' for an upgrade at the rear of their snow cutters ?
I'll leave it to you, I don't have a dog in the fight, I just enjoy digging through stuff to try and find an answer. Now that I think there is a match, I can do a finer sifting of the 411 Snow Cutter piles and see what shows up.
Automotive lighting Wood Rectangle Flooring Tints and shades
Wheel Tire Vehicle registration plate Motor vehicle Automotive tire
1970 411.119 Mystery Mog, 1979 L-1116 Flatbed, 1975 L-1113 Box
TRUKTOR, it looks like just 2 of your pics show a 411c (406 style axle) with the oval lights. Do you have any pics of the 411c with square lights?
Discussion Starter · #16 ·
Probably - Maybe.
View attachment 2803508 View attachment 2803509
Well hell, I wouldn’t want to play clue with you!!! Those are them 100%. Guess I can feel ok about keeping them. Assuming I can resolve the rubber mounts.
If they have custom mounting plates that are of factory quality, then they deserve to stay. That's my opinion.
The one thing I like about the 1300l lights is that the box is metal.
U1450L DOKA
Here is a thought - What if, by the oddest chance, your Ex-Schmidt cutter was one of one with those taillights ? I know, it is an absurd idea, but if you have any paperwork that goes back far enough, and includes the License Plate details, it isn't impossible. It might be tough to prove that others didn't also have them mounted up.
I have not found any other photos of that rig (yet), except for this one showing the front of it.
One clue would be the holes for the extra plate on the right side. You have the usual round medallion ( Silberne Preismunze), the 'Acorn', and then something rectangular above them. It might be a Schmidt Plate, but whatever it is, I think it is a fair bet that they drilled some holes to mount it up.
Schmidt had plates that had the data for the cutter (for example), and these plates were generally mounted right on the cutter or whatever. But they also had rectangular plates that were just Schmidt identifiers, and they did not have the blank spaces to punch the equipment specifics into. It could be one of those.
Wild Speculation.
Coin Currency Money Money handling Cash
Font T-shirt Symbol Emblem Circle
Motor vehicle Tire Wheel Gas Automotive tire
Wheel Tire Vehicle Hood Automotive tire
Barrel Automotive tire Hat Gas Motor vehicle
Wheel Tire Land vehicle Vehicle Car
Motor vehicle Rectangle Font Brick Gas
Motor vehicle Groundcover Font Gas Brick
Wheel Tire Cloud Vehicle Sky
Tire Wheel Motor vehicle Vehicle registration plate Automotive tire
Discussion Starter · #20 ·
I definitely have the Acorn as well as a missing round plate that sat above it. But no Schmidt plates. As well, it’s certainly possible that is my truck pictured there. Certainly a far cry from that now.
1 - 20 of 56 Posts
