406 forst
Tilting the cab on my 1973 406.120 today. After removing the bolt on the steering U-joint I tried to put it back because I needed to repositon the truck. After trying and failing several times to get the bolt back in place I finally made an alignment bolt by grinding the threads off a longer bolt tapering the last inch. With some jiggering I was able to get the alignment bolt inserted. I carefully removed the alignment bolt and did not notice any slippage on the U-joint. But I still can’t get the bolt installed. The bolt has about a 45 degree taper up from the threads which are somewhat smaller than the bolt diameter which I think is the root of my problem. I plan on putting a couple wraps of gorilla tape on the threads in hopes of bridging the steep taper. I tilted the cab back in 2005 and had some trouble but was able to get the bolt installed. Anyone willing to share some tips?
2617631
2617632
1973 416 Doka, 1978 416 Doka, 1980 416 Doka..... Help me, I can't stop buying them!!!
I have never seen the bottom bolt in your photos. In all the trucks I have ever parted out or worked on have a standard 8mm bolt in them with a locking nut on them. So I think your U-joint has been changed out or modified some way. Should have the same size hole on both sides, and the bolt can go in from either side.
