I've just purchased an m180 high compression engine, with twin carbs, manifolds the lot.
I've a 404 doka with 10.5 tyres on, also has a brand new zenith twin choke carb.
I've also a 404 flat bed with 12.5 tyres on, the planned use for this is a tow wagon.
I've been told that for offroading the twin carb set up isn't ideal due to them not being able to handle the extremes of angles?
If this is the case, am I best to swap the head over to the doka, keeping the current twin choke. The doka does get used offroad.
Then bolting the twin carbs to the flat bed to overcome the torque lost through stepping up the tyre size?
Or are the twin carbs OK off road?
Many thanks :bowdown:
