1 - 14 of 14 Posts
Hello ,can someone help me with some info on 404 Gearboxes ,were there any changes in the gearbox [military trucks]during its time of manufacture[beginning to end ] ?is it the same a the 411 box ? Also is this called the F type ? my truck is a 1962 truck .I wanted to buy some spares for it ,for possible future need and just wanted make sure i get the right parts first up ,my truck is 3 hours away and cant check it for numbers etc on g/box thanks for any info
Unimog S 404.114
guude,
the trans (UG1) of the 411 and the 404 are the same and there was no change in any parts over the production time.
only the 2010 and the early 401 had an unsynchronisied trans..
gut mog! justus. .
1981 u1300L, 1998 s280
Yes there are different gearboxes. The internals may well be the same but the casings are different. Specifically the castings at the rear. The earlier box had a threaded casting to bolt the gearbox to the cross member. The later ones used a nut and bolt arrangement which is stronger.
Discussion Starter · #6 ·
Thankyou Maqmog ! thats cleared that one up for me ! cheers
As for engines used in 404 military trucks was there any differences in its production life ? i was told there was, but dont know the specifics
Thanks again
Unimog S 404.114
guude,
dxmedia is right, the very early gearboxes had a different fixing point at the rear, but there was an adapter that is easy to build.
the engines got more and more modern.
the early ones (M 180.927) had a compression of 1:6.8 and an other cylinder head with an other camshaft, it needed sparkplugs with long thread.
then the M 180.928 and a few more with little evolutions, of those the parts are convertible,
the early ones had a different cooler, the engine is, exept of the head with its parts, convertible too.
very few 404.1 had the M 130 engine, a few less had an diesel engine with 60!!! Hp
gut mog! justus..
2015 Rubicon Unlimited (Let the shame be upon me!)
The factory diesels were built for Angola and were OM614/615 family engines fitted to 404.1 open cab trucks. It was a limited run for military purchase. With 60hp they were a wee bit slow, one of the SA chaps here mentioned they were referred to as mobile dunes.
Unimog S 404.114
most of the 404.0 had the M 180 too, there where 113 pcs open, 1151 closed, with the M 130 only 7 open, 520 closed.
the 81 with the OM 615, 60 HP, had the 406/416 open cab.
the bridge between engine and trans was a special one. none of them was seen in the last 20 years, they all seem lost in angola ore mosambique.
Discussion Starter · #13 ·
Maqmog ,cheers thanks for info on engines, still cant find the 404 film on you tube, maybe its been removed ,its an original film ,done in a quarry from memory, a factory film not amateur film ,
1 - 14 of 14 Posts
