Someone PLEASE help a 1981 380SL owner find a good exhaust system for this car. Is there anything that can be done to give this poor beast just a LITTLE more power??? Thanks -Jim
Discussion Starter #2
It's hard to get a little power from that engines setup, but I found removing the vacuum restrictor to the distributor helps a bit. Sorry, I don't know about exhaust.<br>Rene
: It's hard to get a little power from that engines setup, but I found removing the vacuum restrictor to the distributor helps a bit. Sorry, I don't know about exhaust.<br>Rene<p>Thanks Rene, where would this restrictor be? I've heard that removing that small metal bar (with rubber bumper) from above the airflow sensor plate might help w/airflow. Is this a bad idea? -Jim
Re: Re: 380SL...
I am new at trying to find things about this! I need to find a gear box for a 1984 380Sl mercedes. If you could tell me where to look I would really appreciate it.<br> Thanks!
