Hi everybody,<br>
<br>
I am trying to replace rear wheel bearing for my 380SL. I got everything out but the inner bearing that attached to the hub flange. Does anybody know what tool I need to pull the bearing out and where to ger it, thanks.<br>
<br>
Kevin
Discussion Starter #2
Kevin, I have never replaced a Merz bearing, however, if it is as most, you simply use a brass punch to hammer it out from the inside toward the outside. Does this not look it will work? You must be careful not to scar-up any machined surfaces. Sorry, I do not have actual Merz bearing experience.
