Am experiencing the following two engine noises. Hopefully one of you can help pinpoint the problem(s). This MB was recently purchased and I know next to nothing about it's operation. It has 106,000 miles on the odometer, has had the single to dual timing chain conversion, and the A/C has been rebuilt and converted to 134a.
1. Upon cold start there are noises from the front of the engine which sound like belt noise. Applying belt lube does not resolve the noise. Belts are near new, in good condition. The noise lasts for just about two minutes and then suddenly disappears. During the noise engine RPM is about 900, when the noise stops the RPM drops to about 600. Engine seems very smooth throughout event. It occures to me that maybe the oil is draining from the engine overnight and it takes some time for all the components to receive oil. Or maybe the timing chain tension device?
2. After getting through the above and the engine is warm, at about 1500 I hear and feel a rumble which seems to be coming from the front of the engine. It lasts only through a narrow RPM range, say 1400 to 1600. Above or below that range it disappears. Using a metal rod to various topside engine parts and accessories and holding the RPM at 1500 I can not pinpoint from where the noise is coming.
I posted a question maybe three weeks ago about a high speed whine in the rear end and, just recently started noting what sounds like a significant rumble/vibration which I though was coming from the drive train. But now I have a feeling the above noises, especially #2 which just started recently, could be the problem.
Anyone have suggestions for troubleshooting. I have a Chilton's shop manual but it doesn't address anything like this. Have only had the car about a year and have only driven it 1,000 miles. Kinda afraid to drive it until I resolve the above issues.
Would appreciate your input.
Don
Your text hereYour text here
Don
