41 - 46 of 46 Posts
Discussion Starter #42
Hmm... Your tests are indicating you should be getting spark.
I'm late for work. Let me chew on this for a while and I'll get back to you.
I got it started. I was going through the testing procedures listed in the MB manual and everything was good up to reading the connection points where the green wire plugs into the distributor. When I attempted to remove the green wire the insulation material at the plug broke in half. I gave up the ghost at that point and put things back together. Gave it one last shot before I called for a tow and it started. And started again. And ran like a champ. So, I'll put a new green wire on order. You indicated that URO fixed the plug connectors on their green wire, is that correct?
1983 380 SL
Go back and look at post #6. I agree I was cryptic but I would have thought it enough to at least earn a look.
Glad you got it running. (y)
Discussion Starter #44
You have been terrific. Thanks for all of your help! To confirm, the connection on URO green wire now fit correctly?
1983 380 SL
Uro claims they corrected the problem. I don't have first hand knowledge that they actually did correct the problem because I modified the first Uro green wire and it's been working fine.
When they sent me the replacement I just put it in stock.
It's been a pleasure speaking with you. (y)
41 - 46 of 46 Posts
