New hoses, belts, water pump thermostat and running at about 100 degrees. Any ideas? This was at 100kph (60mph) 28 degrees Celsius outside. It stayed pretty constant at this but I’m planning a 200km (each way) run this weekend. Thoughts?
New to you so you have no idea. As Busdaddy said...try an alternate source of testing the heat generated.#1 it’s new to me last fall and didn’t drive it until I had the work done.
#2&3, I’ll assume it’s the correct thermostat and that it was properly burped (reputable old school Benz mechanic) but I could be wrong. Thanks for laying down some clues.
You could check the reciept for the part number and google the number to see what spec it is.I’ll assume it’s the correct thermostat
LOL...all the people in Vaughn sold their house for huge bucks and moved to Barrie for half the huge bucks. I had 2 houses side by side. Sold my primary in 2020 to a family from Vaughn. Sold my rental (primary for 18 months) to an Asian family...guess where from?Alex at northstar used to work on my wagon (newer model) but turned his nose up on working on the 380 (which kinda pissed me off but perhaps he had a bad day). Thanks for the Orillia connection though. I like Ed in SCHOMBERG though - he tells me to hang around and ask questions while he works - and he really knows his way around. One last thing. Congratulations on getting out of Barrie. I’ve got 5 more years then I’m gone too. I feel like I’m living in Vaughan.
Ya. I posted on FB too looking for feedback. Thanks for responding.This exactly where my 380 ran temp wise, until I had to replace the radiator. Now its barley above 80c max, in the Texas heat.
Edit: I feel like I have responded to this before, or there another post with this problem?
how do I “burp” it?Might be worthwhile to burp it again. Sometimes a lot of air gets trapped and it needs multiple burps. Also run the heater at max heat to purge air out of the heater core.
Run the motor from cold then as the gauge temp rises to thermostat opening temp you carefully open the cap of the expansion tank whilst holding pressure on the cap as you loosen it whilst keeping the motor running. Best to wear a heavy glove and also use a rag to buffer the coolant and air escaping. The idea is not to have coolant spew everywhere, it really is just a quick open/close motion to vent/burp the air.How do
how do I “burp” it?
