1987 560SL - Signal Red, 2014 ML350 - Diamond White, 2019 Ford Explorer - Magnetic (company car)
So I had the car in for the first service and I asked about a SW update for the rear-view camera and they told me that they would check.
When I picked up the car they told me that they had updated the SW and that I could also adjust the light my self.
When the car is in reverse, I assume it works as long as the camera is active, you can with the command dial select the [light bulb] sign and then adjust the screen lighter or darker.
Most likely its in the manual but I did not check :grin
