Hi,
We have a 1996 mercedes 308d minibus, it has always had a problem of randomly blowing the indicator/wiper fuse when indicating, a few weeks ago we had a burnout in the fusebox where a wire near the front got really hot and set fire to the fuse box, luckily it was put out before much damage at all was done, (apparently this is a common problem) so we replaced the fusebox and wiper/indicator stalks and all is running fine again.... apart from the same random fuse blowing, not every time just when it feels like it!
Any ideas?
Adam
you need to find where the short is, it may be in the wiring to the indicators at the front. could be the bulb holders in the rear shorting, could be the combination switch,
