1989 300 TE
Recently got my wagon and there is no water coming out of the rear window washer nozzel. The car sat for two years before the engine and other parts were replaced. I tried unclogging the jets with a neddle but still no water. So my question is: Does the water for the rear window come from the same bottle and pump at the windshield?
I can not find where there is a split.
'07 GL320CDI
Separate water reservoir and pump in right rear compartment with your jack. Controlled by switch on upper center console. You need owners' manual!
1989 300 TE
Thanks. I have the owners manual. Found it, I just didn't look down. Didn't expect for it to be tucked away down low. Anyhow, bad news is that it was full. So it must be the pump. Thanks again for all the help!
