I'm planning on doing an MMO soak to see if it will help the smoke coming out of my crankcase. There was no blowby when she was parked two years ago. My understanding is that could be a stuck piston ring which is the primary use case for MMO.
I'm taking my Jeep to Moab for a week and a half...
Since my childhood I always wanted a W123 Mercedes . They represented success in life (to me that was :)) . About 8 months ago , I started my search more urgently . Had a look at a nice clean 300D , but saw it needed to much work for my fancy . A friend of mine told me about this 230E that he...
Are the following Fuchs rims interchangeable? Fuchs 6J x 14:108 400 0902–123 400 15 02–126 400 1902
Can I put them all on my W123?
Thank you.
David in Canada
How did I come to be the owner of this 1985 300CD? Having owned a W201, 2 W124s and a W126 300SD I had read and heard so much about the W123 cars that I knew this would be the next Benz for me. I knew right from the start that it would have to be the coupe body style. I wanted something a bit...
Both sides stopped working suddenly. The driver side switch block is almost new. The other seems to function correctly. I carefully opened the older switch blocks, cleaned them thoroughly, made sure the contact surfaces weren’t corroded, removed slight patina with an Emory board, carefully...
