1 - 1 of 1 Posts
1985 300TD
Hey-Hey!!!,
I just swapped engines in a 1985 turbo wagon. Starts just fine, but the key won't stop it. Pushing the linkage does, as does applying vacuum to the shut off diaphragm( I put in a tube and sucked, engine quit), so I figure the shut off valve is OK. Question is, where to look next? The power brakes work, so there is vacuum there somewhere, just not getting to valve on command. I thank you all in advance for taking time to answer.
regards,
Douglas Piccard
ps. got it as a basket case, havn't driven it. WIth two people, I could look at pressure at the valve line, but have not had help yet.
1 - 1 of 1 Posts
