'84 300TD
Does anyone know how to re-insert or re-install the dash vents. The two outside vents were no longer in the holes when I bought the car, it appeared easy to fix them but it is proving to be a struggle. I figured out how to get the bezel off, the front seperated from the back, but no clue about how to put them back in the dash.
Cheers AG MAC:confused:
'84 300TD
I finally realized the dash vents were both broken by the previous owner attempting some kind of dash ectomy! Both vents outer rings were fine but the inner rings had all the plastic "clips" broken.
81' 300SD, 82' 300D
I have the same problem. I have temporarily solved it by placing the vents outside the holes and running the ducts out of the hole to the vent. They stay in place, but look a little akward. New pieces run at $100 ea. I'm trying to find some used ones in good condition.
