1989 300SE
1989 300SE - always started fine. Haven't used in about 2 weeks. Cranks now but no sign of ignition. fuel pump? Should I hear the purr of the pump when key is turned in ignition before crank? Any other ideas? Frustrated!
2012 CL550 4MATIC Coupe
That or the FPR (Fuel pump relay).
The fuel pumps should run for two seconds, then shut off. They restart after the engine starts.
1989 300SE
300SE - Will not start
Thank you for the info. I checked the relay & maybe a wiring issue, but car started right up!
