84 300sd 85 300 sd 85 300sdl 03 745il bmw 65 mustang 67 mustang, 86 mustang cvt, 91 dodge stealth
Hi I have been here since 04 and love the site. I have been able to maintain my deisel myself and kept her out of the scrap yard. Recently I have a puzzling problem that I have not been able to correct. First the car started running rough. I had been runing a little filtered wvo with deisel about 15% wvo. So I figured I had clogged a fuel filter. I changed both. No help. I checked the tank screen no help. I ran deisel purge through from the tank hose (straight not blended with fuel) Ran great! I then refilled (partially) the fuel tank with straight deisel. Back to the same problem. I checked the hoses on top of the injectors to be sure I had no leaks no help. I had changed the oil recently and put in 15w 50 royal purple and a new filter. The car has no power and can't be taken on the road(stranded twice) It seems to get to a point where it will start run rough and then die. Any help? I love this car and want to keep driving her. I am starting to wonder if its the injectors or the injector pump. But this happend pretty suddenly. Thanks for any assist.
