1985 300SD
I did the citric acid flush this past weekend and installed the new thermostat. I checked the monovalve (recent rebuild) and also checked the aux water pump. All working good. I started the car on the way home from work this morning (25F) and it warmed up quickly. I turned the thumbwheel to max heat and hit economy. I got good heat from all the dash vents. Less than a minute later I hear a click, clunk from inside the dash. Now I get cold air from all the vents. I toggle a few buttons and hit the button for the vents and floor. Now I get lukewarm air from the LEFT CENTER vent only and all others are cold. A few minutes later they are all cold again.
I noticed this yesterday when it was warmer. Of the 2 center vents above the radio only the left one would blow warm air.
Thanks in advance and sorry if this was covered previously.
1991 300 SE
When you refilled the system with coolant, did you turn on the heat with the t stat open and add more coolant if needed? Sounds like the heater core took a big gulp of air.
1985 300SD
I thought about that too. For the entire process of flush and fill I left the heat on full blast.
