1 - 10 of 10 Posts
560 SEC
Hi Guys...
I'm breaking my 560 SEC for spares.. It's a sad day but needs to be done... Alas, I'm watching a much better condition one on eBay as iv fallen in love with them.
Most parts of the car are for sale, pm me for any specific parts you require and I can send detailed pictures.
Lots of pictures throughout thread
Shipping world wide is no problem:thumbsup:
Here She Is....
560 SEC
Discussion Starter · #2 · (Edited)
Interior Parts Numbers-
000 860 01 82 Selt Belt Arm With Motor Etc.. (Both SOLD)
126 820 65 10 Rear Window Switch with Wiring
Left Seat-
002 820 43 42 Head Rest Motor & Spindle Bar (000 821 43 60 also supplied)
002 820 23 42 Seat Motor, Under Seat
002 820 21 42 Seat Motor, Under Seat
126 820 05 26 Seat Plug Board, Under Seat
(another motor under seat missing part number sticker)
0 390 216 693 BOSCH Motor, Inside Seat, for Back Tilt
Right Seat-
002 820 24 42 Seat Motor, Under Seat
002 820 25 42 Seat Motor, Under Seat
124 820 09 26 Seat Plug Board, Under Seat
560 SEC
Engine Components Part Numbers
0 438 101 016 Fuel Sys (27662 745) BOSCH
0 438 121 036 Fuel Sys BOSCH
0 265 200 043 ABS Unit (Relay 0 332 002 171 & 001 542 87 19)
000 158 56 03 Coil (Cap/Cover 000 158 22 85)
003 158 34 01 Distibutor (Cap/Cover 000 158 21 85)
126 830 00 84 Coolant Sys
000 835 69 64 Coolant Sys (Bracket 126 830 18 14)
000 821 46 60 (BERU 0 110 510 030)
Injectors x8 Part number unknown
560 SEC
Discussion Starter · #4 · (Edited)
Electronic Control Unit / Box Part Numbers- Removed, boxed and ready to go..
005 545 21 32 ECU
004 545 00 32 EZL
004 545 25 32 KE
124 820 51 10 RS-RSR Crash Sensor
003 820 45 10 Temperaturregler Temp Control box
004 545 11 32 Idle Speed Control Relay
000 820 58 26 Seat Belt Arm Control x2
002 545 18 05 Relay, Red, Fused
000 800 09 48 Box in Trunk
000 821 02 62 Box in Footwell
000 820 02 97 Box in Footwell
005 545 05 32 Box under Steering Wheel (Including Relay 005 545 07 32)
005 545 33 32 Relay under Steering Wheel
001 545 87 14 Door Shut Push Switches x6
126 540 33 35 EZL Wiring, Dash to Connector
EZL Dial
ECE Dial
Body / Exterior Parts Numbers
126 880 08 60 Bonnet Stay Right, Left available, aswell as Bonnet pull cable & lever
Front Fog Lights x2 Pairs
Rear Right Light Lense Euro BOSCH part
Boot Lid/ Trunk Lid, Straight Panel, With All Badges, With or Without Hinges (Chrome Trim is Dented)
560 SEC
Discussion Starter · #7 · (Edited)
Sold Parts List These parts are sold and gone...
Oil Cooler Assy
Cam Shafts & Rockers
HeadLights & Indicators
Seat Belt Mech's
Kilma Relay
EZL Module
SunRoof
Rear Seats, Head Rests & Arm Rests
Door Windows & Rear Windows Chrome Trims (long ones)
Front WindScreen Chrome Trims (x5 pieces)
Right Side Door Glass
Lorinser Wheels
Electric Mirror Switch
Rear Left Light Lense
560 SEC
Discussion Starter · #8 · (Edited)
Oil Cooler Assy- Sold
Oil Filter Housing
Cooler Core
All Lines/Pipes
Thermostat
Brackets
Bolts etc..
Excellent condition, no damaged to any other the fins etc.. Ready to fit:thumbsup:
Unfortunatly none of the ducting between the bumper and cooler are not present.
£200 plus shipping (approximately £70 to USA)
Door & Door Shut Chrome Trims / Covers
Centre Console Trim / Panel / Surround.. Switches- Windows, Hazards, Heater Controls, Recurc, Heated Rear Windscreen, etc..
Steering Wheel AirBag, Front Door Glass Brackets, Door Check Straps, Wing Mirror, Rear View Mirror Bracket & Sun Visor, etc..
560 SEC
Discussion Starter · #9 · (Edited)
ABS Module
Door Shut Switches, Control Box, Wing Mirror Interior Cover / Trim
Fibre optic octopus + Heater / AC controls / dials etc + centre trim + rear window switch
Parts from left side of car, Seat Motors, Seat Belts Front & Rear, Front Head Rests, Arm Rest,
Left & Right WindScreen Wiper Arms & Wiper Blades.. (RHD)
560 SEC
Discussion Starter · #10 · (Edited)
Engine Serial & Part Numbers
Block Serial Number
117 96 822 036035 HV (10:1 Compression Ratio, Rare 300hp Engine)
Block Part Number
117 001 24 01 (27 113) (87)
Head
L 117 016 45 01 (1)
R 117 016 45 01 (2)
Gearbox
126 270 70 01 722 323 02 982 273
126 271 31 01
1 - 10 of 10 Posts
