1 - 9 of 9 Posts
1989 300E 200,000+ miles
Hi everyone,
I've seen the awesome wagon undercarriage rebuild that aqorps/Raj did to his 93/300TE.
I was thinking, has anyone done one to a sedan? I'm still learning so is the rear end in the wagon the same as the sedan with exception of the levelers? If anyone did rebuild their undercarriage did you make a parts list? Take picture?
Discussion Starter #2
Im casting my fishing line out again and changing the bait. Has anyone wanted to do the undercarriage and would be interested in helping make a list? Anyone?
Jean:)
So is the rear end in the wagon the same as the sedan rear end diff. and all?
Mercedes 300 TE 24v SportLine -91 W124
I think that there are different versions of diff's out there with different ratios depending on engine or what ever. I am not sure on that point.
Cruise Control
'87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
There are differences between the wagons and sedans, but they're relatively minor in relation to all the work needed to rebuild all the links and bushings. The agorps rebuild and the DIY sticky should be sufficient information for work on either chassis.
This is a truth with a modification as I have not had those aluminum torque bars on my station wagons but the iron ones.
This on my -88 and on my -91.
Cruise Control
When I bought my wagon, it had those steel torque arms on it as well. The only appreciable differences between the sedans and wagons has to do with the struts, lower control arms, swaybar links and wheel bearing carrier housings. But all the R&R procedures are the same
Thanks Zeitgeist thats the answer I was looking for but couldn't find in the post of the wagon.I'm surprised that no one has done one to a sedan yet.
Yeah I need to get the dancing on the freeway fixed. Mercedes doesn't dance well.:)
1 - 9 of 9 Posts
