Will a 1987 300d automatic transmission work/fit in a 1987 190d turbo ?
If not, what is the difference?
It is my understanding both cars have the same engine.
Thanks in advance.
It should. 190's and 300's used the same transmissions (less the 4-Matic). Do you know what number your transmission is? Like 724.XXX
I'm curious if EPCnet online is able to pull up trans codes with vin numbers too
The 1987 190DT is 722.413 and the 1987 300D is 722.317
I've got a 2.3 transmission in my 2.3-16 and it's not the same, but works. I know it will bolt up and you'll be able to use it, but shifting points won't be the same.
