ive been doing some research, in books, manuals, online, and have come up with these specs + history for my 83 300d... is there anything anyone sees/knows to be incorrect? if so, let me know... thx!
White 1983 Mercedes-Benz 300D Turbodiesel
Model – 300 D TURBO
VIN – Wxxxxxxxxxxxxxxx6
Manufacturer Name – Daimler-Benz
Country of Manufacture – Germany
Production Plant - Sindelfingen
Production No. – 034156
Engine No. – 056165
Year of Manufacture – 1983
Dealer Name – Ray Catena Motor Car Corp. 910 Route #1 Edison, N.J. 08817
Delivery Date – 9/30/83
Chassis Code – 123.33
Weight – 3515lbs. / 1.7575 tons
Engine type – 617.952
Work cycle – indirect injection diesel four stroke
No. of Cylinders – 5
Cylinder configuration – in line
Displacement – 3L (2998cm3 / 183in3)
Compression ratio – 21.5
Output – 89kW / 120bhp / [email protected]
Torque – 230N-m / [email protected]
Cooling – water cooling/pump, 12L water
Transmission – Automatic four-speed torque-converter transmission
Type of gearbox – planet gear
Availability – series
Clutch – hydr. Torque converter in autom. gear
Gear transmission – I. 3.68, II. 2.41, III. 1.44, IV. 1.0, R. 5.14
Differential ratio – 3.07
Drive axle – rear
Max speed – 165km/h / 102.5mph
Fuel – Diesel ASTM D 975, grades 1 and 2, VV-F-800a grades 1 and 2
Fuel capacity – 80L / 21.1gal, 10.5L / 2.8gal reserve
Steering System – power steering
Steering transmission ratio – 16.55:1/3.2 steering wheel turns
Front/rear brake disc diameter – 278mm/279mm
Restraint Systems – Seat Belts only
Model – 300 D TURBO
Engine No. – 056165
Drive axle – rear
