1 - 20 of 22 Posts
1996 w140 300d, om606.910 non turbo 24v, 265k mls
hi all. I benefited from this site so many times - so it's time to give some thing back...
i just bought w140 (originally 2.8 petrol - now 300d)
the car was converted about 10 years ago by one of the best mercedes indie's in Ireland.
it's w140 with om606.910 non turbo straight 6 engine, automatic
LOVE S-class
so today i went to my friends garage and decided to change the fuel lines(there was air in the system), as i was at it - return lines were changed, fuel filter, oil filter and new oil, new glow plugs, modify intake manifold, belt tensioner and shock, cleaned IM from some of the gunk..... and some more
Discussion Starter #2
so i said to my self why not take some pics ....
i started by removing a intake manifold
in my car it's held by 2 10mm bolts on drivers side
and on the other side of the engine there's bolt holding vacuum line
i took 2 10mm bolts (red arrows) from the top of fuel filter (it loosened vacuum line so i could take IM off without damaging vacuum). they were holding vacuum line (white arrow) and securing 3 fuel lines from coming out
then i removed 2 10mm bolts holding accelerator cable assembly and one for gearbox cable holding bracket
disconnect the accelerator rod from the bracket
now i was able to lift out the long and narrow piece of IM (i don't know the proper name for it)
look out for vacuum line connected to the back of it...
i cleaned the top of the engine with compressed air because i was about to go at intake manifold it self... you don't want anything falling inside ....
undid all bolts holding IM (there's a lot of them)
and lifted IM off - again - watch out for vacuum lines at the back of it
and try not to damage any fuel injector lines as you taking IM off....
my engine looked like that without it
since the manifold was off i went at the glow plugs
there's some pics of different types as i was told
and that's the ones i've got(you can't go wrong with originals)
no 1.2 and 3 came out without any problems - but other 3 - REAL PAIN in the .....
that's how they looked.....
next - plastic see trough fuel lines
i was thinking to change only o-rings- but the 4 lines at the dealer came to €45 - so i decided to change lines as well
some difference.......
Cruise Control
'87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Nice write up. On my 606, I opted to convert all of the o-ring junctions back to the old style with the copper crush washers, since those rarely leak. What is the immobilizer you reference in the glow plug pic?
first i did short line on the top of fuel filter
10mm nut (yellow arrow)- remove
nicely lift one end of the line by fuel filter (i used the help of fine flat screwdriver)
other side is held by clip- unclip that one - and pull of the line (red lines is where they go)
BTW - all the lines come with o-rings (difference between o-rings on they own and lines with them was VERY small)
next - fuel strainer
carefully lift strainer of the fuel filter assembly
remove - clean with compressed air ( or with the help of your lungs :) )
there's o-ring to be changed
next- put strainer back into place it came out of.
i connected far end first (easier to fit last connection where's more space)
thanks a lot Zeitgeist. i've bought other glow plugs few days ago - you can see them in a picture- tread was same and size was very alike - but connection for wires is different. immobilizer ones have to be connected to ecu + IP + glow plugs (safety feature, anti theft)
i have connectors on IP not connected as well - so i assume they were never used because of the conversion - ecu is from w126, engine and gearbox w124, w140 chassis..........
Always replace fuel pre-filters and the filter in the fuel tank. Not worth taking a chance re-using such a cheap part when yours is looking so old an dirty.
Please update your profile so we know which vehicle you are referencing. The OM606 was only used on the '95 W124 in the US. The W140 initially had the OM603, but was superseded with the OM606. Only the OM603 was available in the US, which had the dreaded "rodbender" 3.5L turbodiesel.
there's line with banjo bolt on the side of IP - connect that first and then fuel filter side.
watch out for small o-ring on the bolt
Cruise Control
He mentions that it's a 140 gasser that's been converted over to a 606.10, so it's applicable to folks here with the '95 E300D
I would most definitely also replace the main vacuum line running from the vacuum pump to the brake booster.
Yours is being held together with duct tape.:eek::eek::eek:
If that line lets go, you will lose brake assist and won't be able to shut off the engine since your main fuel filter does not have a manual shut off valve. This is a serious safety issue to yourself and to other motorists in addition to preventing a runaway diesel situation.
Discussion Starter #13
thanks for the comment sbaert. i didn't replace pre-filter yet - because dealers didn't have it on time for my DIY.
didn't update my profile yet,
it's w140 1996 - originally s280 - but converted to 300d
engine and gearbox are from w124
om606.910 - is non turbo 24 valve head - one of the best uncomplicated engines ( if not THE best)
it has 265000 miles on the clock - no smoke on start up (after glow plug change), no black smoke on take off or acceleration, so silent- people can't believe it's diesel
Discussion Starter #15
it's foil to divert some of the heat from metal and rubber connecting parts
thanks for advice sbaert. i'll do that on my next day off next week
Discussion Starter #16
back to DIY
next - fuel filter - 17mm bolt on the top- unscrew- take the bolt out
there's 2 o-rings to replace
fill NEW fuel filter with diesel or injector cleaner (removes the need of IP doing a lot of pumping ) and put everything together
Discussion Starter #17
NEXT - belt tensioner and shock replacement
you should be able to do that without taking the fan out
undo the 13mm bolt holding the tension spring, undo 13mm bolt holding tension shock
remove or take down the belt
now is the time for tensioner assembly
17mm (i think hex) - unscrew
keep doing so until bolt is gonna be cumming out of the assembly - easier removal
Discussion Starter #18
put everything together and reinstall or renew the belt (witch i did)
Discussion Starter #19
some pictures of old assembly
re bolt new shock and pulley onto new assembly
Discussion Starter #20
since i pulled of the cover off- i decided to check breather pipe and all the lines coming out of it - OMG
1 - 20 of 22 Posts
