'86 W123 200, OM617 non-turbo, bastard 5-speed; '95 W202 C250 Diesel, OM605 non-turbo, 5-spd man
Does anyone know how the fuel level sensor works?
My fuel gauge shows more thatn a quarter tank left when the reserve light goes on. The reserve light is the more accurate indicator, based on tank-to-tank calculated consumption. I suspect the cause is an electrical phenomnon called "DC drift". I would like to fix that if I can.
Thx
PlaneCrazy - it's more than a name, it's a life choice!
This is a common problem. Do a search for "fuel sender". It can be taken apart and cleaned easily. It's underneath the first aid box in the rear parcel shelf. To remove it you'll need a 45MM socket or equivalent. Be careful when disassembling it as the internals are fragile.
OK, so I've taken it out and taken it apart, cleaned it up, reinstalled it... and wasted my time. Which other cars (Mercs?) use this sensor, so I can replace it? Is the petrol and diesel model's sensor the same?
I noticed that the copper wire in the center appears to be a bit slack. Could that be the cause of my woes?
