1984 300D
My 1984 300D Climate Control continues to give me issues despite re-soldering joints on switch panel, etc. I have recently purchased a used switch panel as well as the related switch boxes that are part of the system. The parts are from a 1985. Does anyone know if the dashboard switch panel is compatible from an 84 to an 85 without replacing additional parts? The reason I ask this is the panels are the same with the exception of the (E) Economy switch is in the middle of the panel instead of the right side next to the off button. (The connections appear to be the same from unit to unit)
Thanks, Steve
'89 300TE, '79 450SL, '01 ML320
They are the same, someone put the buttons back on wrong.
Fish
1967 250 SL, 1965 300SE lang
From my research, all W123 cars with the automatic climate control push button panel are the same, and do NOT interchange with non-W123 cars. I agree, someone put the buttons on wrong.
1984 300D
Thanks everyone who posted on this. You are right and the part numbers match. Must be the buttons on incorrectly like you said. The good news is the unit seems to work well and my blower now works properly in all modes. I still have a pesky problem with no or intermittent leg heater flap operation will start looking for vacuum issues after I correctly install buttons.
Best, Steve
