A 606t is originally an ECU managed drive-by-wire engine that works in conjunction with a similarly managed 722.6 transmission. So, you need to determine whether you're carrying over all those electronics, or whether you're going mechanical, which then requires lots of conversion parts from a 603t car, which is what I'm doing. Complicating things for you is that you're starting with gas powered car, unlike me. It's doable, but it takes hours of commitment to poring over electrical diagrams and such. The engine itself should fit right in, though I'm not sure about the engine mount brackets on the 103 being compatible with the 606
