1 - 9 of 9 Posts
Does 3000 RPM at 70 MPH seem right ?
My car (I obviously just got it) has plenty of power (relatively speaking, of course), but still, that seems like a lot of revs at 70.
At 80, it's like 3400-3500, and....well, I haven't gone faster than 80 :)
1991 300 SE
All five and six cylinder MBs of this era are geared to run at high rpm at those speeds. It's normal.
1983 Benz 300SD
I have a 1983 300SD and at 70mph the rpm should be at 3000. I also notice when I am driving at around 75-80mph, the temperature tend to go up. Keeping it at around 70 mph and temperature should be steady.
f1crazydriver said:
At 80mph my car seems to run at 3200ish rpm, is that good or bad?
The early Euro 500's had 3.27 rear ends, from what I've read. Meaning, at a true 80 mph, rpm should be about 3.5 - 3.6K. That's where your's should be at, with the stock wheels/tire combo. Otherwise your speedometer optimistic by 12%.
Under acceleration, I've found these electronic speedometers lag behind a bit. So even though your speedometer is optimistic when static, under acceleration it will appear more accurate.
500 SE EURO!
Hmm i have a diffrent tyre setup then stock perhaps thats why ? it would lover it a 200rpm im assuming.
1 - 9 of 9 Posts
