My car is in excellent condition and has 160k miles.<br> <br> However I have one problem that I can not figure out. When I make a hard right or left turn I am getting a noise from the rear end. At first I thought it was the exhaust shifting and hitting the frame. As I have an after the market exhaust. But after placing new rubber bushings and making sure it is not shifting the noise still persists. Has anyone had this problem?<br> <br> Monty<br>
It could be the halfshafts, diff bushes, control arm bushes, wheel bearings. Somethings worn and you need to see what's got too much play in it back there. Have you secured the spare tyre properly? A specialist may be needed if you can't find it cause' noises can be very hard to diagnose.
