300 SEL- 190D- 380 SEC
My 300 continues to have a bit of a hic-up. She don't seem to happy w/all the attention I've been giv'n her. I have replaced the pluggs, cables, rotor & cap. She's been a little better but should I replace the coil as well? It tends to "bogg down" at inoportune moments and not stay lit after I start her ... or would some chocolate & roses do the trick...
1991 300 SE
The coil is possible – does it do this hot and cold? Is there excessive cranking or smoke? Overheating? Poor fuel mileage? How many miles?
(I hope none of the above is classified…)
Mostly when cold, 202k miles, no smoke or overheating, I'm about to find out the desert isn't known for its kind summers.For the moment your cleared for Benzo classification, how-ever I think the the fuel mileage may be, haven't checked.[:p]
1991 300 SE
Ok, over 200,000 miles – as noted before check the coil – rule out a spark problem. If that checks out we’ll move on the fuel delivery and engine management. It could be anything from a failing fuel pump relay to the OVP relay to a bad fuse. [:(]
How exactly does one go about checking the coil?
1991 300 SE
The best and safest way to test the coil is on a scope – there is very high voltage (hence the lighting bolt on the air cleaner) and I would take it to a shop for a test.
