1991 300 SE / 1983 280 SL Euro
i have a 1991 300 se and I finally got the radio code and the radio now works. i am however a little confused with how the ch changer works. I predd the mode button and it says CC which i know means Compact Cassette. When i press it again it goes back to FM radio. a couple times i have gotten it to say load and a number, i can hear it shuffling the cds, it will say load 1, load 2, up to load 6 then it will switch back to fm radio. Does anyone know if it sounds like its broken or maybe im pressing the wrong button.. maybe there is a special trick to this unit. Again i have a 1991 300 SE with becker silverstone 10 disc cd changer in the trunk. It is the stock unit.
1989 300SE (Rear Ended & Junked) 1995 E420, Fully Loaded with Ortho Seats & Rear Sun Shade :)
I am guessing that you have the 1432 unit & the changer unit is Silverstone Model 980 (2630) 10-disc used in 1991-1993 Mercedes models.
Attached are the manual and installation guides:
Thank You the manuals were helpful but now I know that i am not doing anything wrong. It must be the unit. Does anyone know any possible troubleshooting tips? is this a common problem that can be solved?
Becker 10 disc cd changer available
I have a 10 disc CD changer and the tuner and tape player from my 1992 500SL that I would like to sell to a good home. Was remover recently when I got a new radio with blue tooth and satellite. All worked fine when removed.
