2000 E430 1990 300CE
I just helped my son find a beautiful 92 300 CE with only 90K on it. The right rear window doesn't work. I am sure it is the tradional faulty MB regulator. Doe anyone know how to get into the rear panel to change it?
On another subject, How do you get to the spark plugs on the DOHC engine? I have had 2 300 E's, but they are differet engines with the plugs easily accesible from the left side.
1984 280SEL AMG
You spark plugs can be gotten with most standard spark plug socket, it has a little rubber thing in it that holds the plug for removal, ( I have the 2.8 DOHC ). Tho the rubber in mine is quite worn, had to use needle nose pliers. As to the non-working window, the panel should remove easyly once you remove all the screw in items, by sliding it up NICE AND EASY.
