w111 3.5 coupe
hey there
im looking for which is the best tyers for my 3.5 coupe
whats the best size
thanks i like everything stock
W111 Coupe
It depends on the speed rating which in turn depends on how fast you want to drive your car, even occasionally. Originally that car came with 185/82-VR14 tires. The closest to that is 195/75-14 but I don't know of any being V rated or even H rated. You can find them with a white strip.
A popular replacement size is 205/70-14 and you can still find them H rated, good for 210 km/h. You can get then V rated if you buy some classic XWX Michelins (a very common choice for that car back in the days) or Vrederstein but they're expensive. No white strips.
Personally I believe the 3.5 Coupes and their low front grill are better with biffier 205/70-14 black walls which was a replacement size officially recommended by Mercedes. H rated is enough for most applications (if not all). Then you have a choice between cheaper modern design or more expensive classic design.
Mercedes 280 SE 3.5 coupe, pagoda 230 SL '64, 500 E W124, CE 220 Cabrio, E 320 T W211, w126 6.0 AMG
cost
The 205/14 are not very cheap, so in germany frequently we use the W126 steal rims (15') with 15' steal caps (W100 or ambulance) or the barock 7x15 Fuchs/ATS designed rims with 205 (215)/15 on it.
best pagodino
