1 - 9 of 9 Posts
1979 280SL, 1984 280SL
My 1979 280SL is equipped with a 4 speed manual transmission. Currently, it is filled with 90wt gear oil. I find shifting to be somewhat sluggish, and slow to warm up. It can be hard to shift cleanly when cold.
Many years ago, I had a 1979 240D with a 4 speed manual, and remember that the factory recommendation was for ATF, which is what I used. I don't recall any complaint about shifting in that car.
Any thoughts on switching this gearbox to ATF? I am assuming (but not certain) that ATF would have been the original lubricant. I am sure I would need to change the lube a few times, and install new shifter shaft seals. Any thoughts?
Thanks!
Outstanding Contributor
450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro
The gearbox is really similar to the much more common 240d manual transmissions. I bet you can use information about a 240d and assume it applies to the 280sl.
Edit: I found this for the 240d
2007 ML320CDI, 1959 220SE, 1971 280SL, 1982 380SL
The transmission should be filled with ATF. (Dexron is ok) They often get missfilled by those that make assumptions they should not.
Thanks guys, this is what I was thinking. I am certain it will shift a lot better once done!
75, 280Sl /5speed
And don't go by Benz's fill amount recommendations. Like the transmission manufacturers say, "fill till it spills".
1984 280sl 5spd, 02 E320 4matic, 79&79 450sl part-out, 78,79,81,83 300CD, 79 280CE
Thanks!
When I got my 84 280SL 5spd, the tranny had been filled with 90w. It to was hard to shift, and made a "whirring" sound almost like a bad throw-out bearing. I drained the 90w,and filled with ATF. Flushed the tranni about every 400 miles for the first 1200 miles or so. "Whirring" went away. and tranni seems to be OK, but I did fine these teeth after draining the 90w. That was 4 yrs/10K miles ago
2610629
1985 280SL 1980/1983/1985 280TE 2004 320E, Healey Lemans & Tri Carb, XKE, 73 911S
I have owned a 280TE with manual Trans for 25 years & used the recommended ATF for most of that time without issues & long trans life. I switched to Redline MT-90 synthetic manual trans oil & found improved shifting at all temps.
1 - 9 of 9 Posts
