I’m having issues with my 280SL 1983 M110. Ran great when the warm before and after replacing the fuel pump I cannot start again.
System pressure is 75 psi when jumped fuel relay and cranking. After stop cranking and disconnecting relay jumper the pressure drop to 48 psi and hold as required. I checked the spark and it is. I checked the return line and does not have restriction.
Has anyone else experienced this problem?
What I should do next?
