21 - 26 of 26 Posts
R/C107 Moderator
I see two pictures. Are you just showing one of the partitions?
1998 ML320, 1975 280C
Pictures are now there. The fluid in the back partition looks dark, but that could be the light. I think you will need to check under the car and bleed the slave cyl.
1983 280SL 5 Speed
Discussion Starter #24
The 2nd photo is of the rear partition for the clutch. It's hard to see, but the level looks right.
Yeah, I'm looking into that. I have a feeling that the slave cylinder is the problem here.
Don't for get to inspect the line going to the slave! there is hard line and rubber, and the rubber line may be leaking.
21 - 26 of 26 Posts
