Hey Guys,
I hate that my first post here is such a complex one - I've been lurking around this site for a long time but I've got myself in a mess and I'm hoping someone can help so thanks in advance for any insights....
I recently picked up a very nice, original 73 280sel 4.5 but like so many of these cars it had been sitting for a while.
I've been methodically sorting through lots of issues. It still runs like crap. When I first started digging into it I found that the fuel return was blocked and it was running 90psi in the rail, obviously running rich. It also had massive intake leaks which were counteracting the extra fuel and it was actually running pretty decent, albeit very rich. Long story short - I've fixed the fuel pressure and vacuum leak issues. Its running lean - it runs OK if I bump fuel pressure to about 60-70psi by crimping the return line. I've been through the tests on all sensors, adjusted tps, all new ignition components and checked timing. Pulled/ cleaned / tested injector trigger points. Could running at 3 times the standard fuel pressure have damaged the injectors? My gut tells me yes but I want to hear it from someone else before dropping 700 bucks on a new set. I have confirmed that they are all firing - however they are shooting a straight stream, not a nice atomized cone that I would expect. Any other thoughts? I've swapped ECU's as well and its runs about the same... Will not even idle at 30-40 PSI in the rail unless I disconnect temp sensor 1 which should make it richer...
Fuel pressure regulator is new, fuel pressure seems to be correct now at about 30psi, MPS tests good (holds vacuum at 10 hg and the resistance readings are correct across the pins).
TS1 (coolant) 1.541 k Ohm at 77F
TS2 (ambient) .372 k ohm at 59F
TPS tests correctly at closed setting and fires 20 times as expected when actuated.
Thanks for any help!!
Nick
Nick
