My 280GE ('87) has a new problem.
I just replaced the starter (it burned because it started suddenly to crank while the engine was running !).
With the new starter it initially looked fine. I left the car standing for a couple of weeks and wanted to start it again.
Symptom:
If I turn the ignition key the engine want start (you can hear a relay "click") after a couple of times trying it just cranks and runs instantly.
I did already check the ignition switch: looks fine, no bad contacts.
The starter is new and it is a lot of work to replace it, so don't want to start their.
Battery is also fine.
Question:
Is there any relay (other then the starter-relay on the starter itself) between the ignition switch and the starter or is it just directly connected to the switch ?
Any suggestions on how to solve this ?
Symptom:
Question:
