41 - 60 of 70 Posts
1981 W123 280E "Rusty", 1987 W124 300E "Hans"
Discussion Starter #41
Why can't stuff just be easy?
Well, I found another problem, something I had overlooked earlier: the thermo-time switch wires.
I found them resting up against the exhaust manifold, as they probably had for the past 10 years, in the condition of burnt split insulation and melted fraying copper wire. Thinking this would be the solution, I spliced in new wiring (safely, don't worry) and tried starting the car again. To no avail.
At this point, I have checked the primary wiring, the fuel distribution, the fuel pump control, most of the cold-starting system, and I am at a loss. Is there any mistake I could have made during my digging around that would cause the engine to run so rich that it can't start?
I may have also screwed up (literally) the mixture control screw while I was cleaning the air valve. Does that setscrew connect with mixture richness, and/or will adjusting it properly give me the right mixture?
Is it just me, or do those two sensors look like they've been hit with a hammer?
Discussion Starter #42
Es läuft! Es läuft!
Well, after some fiddling around with the idle adjustment screw, I was able to get Rusty's engine to start AND idle! It's still a bit off, but at least the bloody thing runs right.
In honor of the 1-year "anniversary" of my custody of this car, I took it on a little drive around the block(s) to work the transmission and brakes, as well as the engine. Sure, me going about this whole procedure of taking a half-disassembled car on a public road where the more civilized people drive was risky, however, few people so much as looked up, so I figure driving rust buckets with no interiors is pretty normal around here. Being as the floor had little to no weight-bearing ability, I had to lay a piece of plywood down (they all tell me to just fix the floor with plywood) across the crossmembers to reside on. When upon that plywood board, I cannot say the comfort and ergonomics was what I have come to expect from the engineers of the three-pointed-star.
Although the welding portion of this project is likely to come a little later than I had hoped, it will indeed happen. Using a future-purchase Harbor Freight MIG 140 welder, I'd like to weld in patch panels cut from a Klokkerholm full left-side floor pan and a lower right-side pan, and maybe their trunk floor/rear fender repair panels. The rest of the smaller holes I could probably get away with repairing by using unnecessary body panels from our mournful Subaru station wagon (victim of fallen hemlock), hopefully it is not galvanized. Expect to see my lousy attempts at panel-bending soon.
It's probably invisible in these pictures, but I have tested out my carnauba wax on the left doors (it's okay, they're clean!).
That's my update for today, the Mercedes adventure is just beginning.
Discussion Starter #43
The Turning Point
Monday's update. After a whole month.
This thread has been quiet, but Project Rusty has not. We finally dropped 584 dollars and 89 cents (excluding sales tax - $50.89) into a Harbor Freight 140 MIG welder and some basic equipment. Once I get some practice in and the settings tuned correctly, I should have the body done soon. At least, we'll see.
But that's not all...
One thing that was really driving me crazy about this car was the ridiculous amount of play in the shifter. So, I decided that it had to be fixed sooner or later, and I bought my first set of new parts for this car! Specifically, a set of shifter bushings and spares, the "required" installation tool, and a brake pedal pad, all from MercedesSource (supporting local businesses and all). It shipped fast too, since their warehouse is a mere mile from our residence. During the installation of the shifter bushings, I learned that one bushing was easier to install than the other - I almost had to remove the arm on the side of the tranny. On the other hand, I can now get the transmission completely into "Low" gear!
Concerning bodywork and welding, and now that I am going to be welding, is there anything I should know before letting the arcs fly everywhere? That is, besides having the ground clamp as close to the working surface as possible, adequate personal protection, and covering all windows and (valuable) painted surfaces with something not flammable? Should I stay outside of the car and not touch it while welding to avoid being electrocuted? Dumb questions, but I would like to play it safe when it comes to this project.
I've made it my goal that I'll have all this done by Rusty's 40th anniversary (I have 2 years).
Discussion Starter #44
Tuesday's update - this update is more my attempt to play around with this new forum software.
Since I first got the car, I hadn't had a chance to get a really good look at the rust around the luggage compartment area (note - not "trunk" or "boot"!). When I started tearing the car apart, I didn't have any place to put the stuff I removed, that is, besides the luggage area. I also wanted that stuff out so I could drain and remove the fuel tank before welding in there (for safety reasons). So, on Monday, I spent a decent amount of time transferring all that stuff (the whole interior) from Rusty to our seldom-used Ford Ranger with a rear canopy. In doing this, I will guess I raised the rear suspension up several inches.
Here's the 'compartment after I emptied it, the day before I cleaned the dirt out. I guess I can paste images in place!
2602385
And here is the compartment a day later. Note the inside white paint and the turn signals.
2602389
Here is the left lower recess, with a red sheet to highlight the rust hole. (I LOVE THIS!)
2602390
2602392
2602393
And here is the right lower recess, the one with the big hole. It actually doesn't look too bad, labor-wise.
2602394
2602395
2602396
I don't know about the spare tire well. There are some holes, but it doesn't look TOO bad. Should I just cut up a patch panel for it? I do have a non-destructive plan for the rusted spot weld seams around it, though.
2602397
I also spent some time cleaning up the front fenders. There is a painful amount of rust along the lower seam, and a big hole on the corner (applies to both fenders). The rock guard sections seem to be pretty beat up, with many large dents and scrapes. I think somebody sprayed black undercoating on the rock shield to try to "fix" the rust that was already showing up there; and what a mistake that was. I would like to try to repair the fenders I have, instead of buying new ones, just so I can keep the job of painting the car to a minimum. It's going to be interesting trying to patch that convex hole with a flat piece of metal.
Almost 2 weeks after I first bought my first welder, I finally had the chance to get it outside and lay down some poor cheap-flux-cored-wire beads. The wire that came with it is unimpressive. Is there a known better flux-core wire I can get for this welder, preferably not from Harbor Freight?
That's all for now, tomorrow I may try welding on the car using sheet metal I cut off an old microwave (low-grade, I know).
Uploading and placing those pictures seems a bit easier than before "the Update".
85 Audi Coupe Quattro, 71 BMW turbo 2002, 73 BMW 2002tii, 85 BMW 635csi
Get some .030” Lincoln flux from Lowe’s or Home Depot. Like $15 and be sure to get the same size tips. I’m assuming you have an induction knob and burnback setting on that inverter welder?
If you can get ahold of some thick copper, put it behind where you weld to control burn through and wasting wire.
Voltage setting should be low and wire feed about 2-3 range. Most likely a rough guide on inside of door of welder. Make sure polarity is correct. Ground clamp to + and wire feed on - for flux core.
Also take great care to never kink the wire feeder or you’ll risk damaging the liner.
If that metal from old microwave is galvanized, it won’t work so hot, weld will be weak.
Be sure to wear sleeves, gloves and mask at all times when welding. Can get a nasty sunburn on your skin and eyes in the middle of night will feel like someone sticking needles in them for hours on end.
I know I told you before, NO BRAKE CLEANER for cleaning anything you’re going to weld.
Discussion Starter #46
Thanks for the info, it sounds like you've gone through this before!
On the welder, I've got 3 separate controls. Wire feed speed, voltage, and inductance, respectively. There is a simple chart on the door with basic settings for various thicknesses and wire types. I'm gonna screw around with the settings a bit on the old microwave before I try on Rusty and end up burning holes through my floor. The metal the microwave is constructed of (which isn't galvanized) could be used to patch some of the body, but I really don't want to use metal of a quality that probably only works well for kitchen appliances.
Why shouldn't I use brake cleaner? It's not like it says, "Do not use on welds - fumes can damage respiratory system"! I'd rather just use a wire brush.
I'm also interested in knowing of some of the recommended post-coatings for the repairs once I finish them. Weld-thru primers, rust encapsulators (the broad category), moisture-neutral seam sealers, cavity waxes, and if any of the final rust coatings are paintable. I don't necessarily want to know of "the best", I just want to know what other people have had success with. I'm leaning more towards POR-15 over the majority of the (future) welds, but I don't know if I can topcoat it in the areas I want the factory paint color.
Finally - I just ordered a full driver's side floor pan from FixRust. I didn't order anything else as I wanted to establish them as a reliable place to buy from. Plus, I wanted to see what the quality of the metal was before I dropped a paycheck on their site. All seems to be in order, all I can do is wait until it ships.
Discussion Starter #47
Friday's Update - Wheel Arches!
Specifically, the front wings and the left rear wheel well.
Due to yard work and a lack of storage space, I decided to re-hang the front wings on the car. That, in turn, did two things. One, the fenders are much less likely to sustain damage during the demolition of our garage. Two, seeing the car with the wings back on it motivated me to start cutting out metal. That's the topic of this update.
Motivation...
2603413
On Thursday, I got the sudden urge to fix the rust around the rear wheel arches (didn't I say that already?). That evening, I got the car jacked up and the LR wheel off. I proceeded to scrub the daylights out of the wheel well with my trusty (and effective) dish scrubber, and a bottle of spray degreaser. From there, I analyzed the real extent of the rust, and was pleasantly surprised by how easy it looked (knock-on-metal). The next evening, I finished up the scrubbing (OCD?) and wire-wheeled away at the smelly undercoating.
The result was this:
2603414
After I had located all the rust (by beating the hell out of it with a screwdriver), I started cutting:
2603415
Yep, that's all I have done so far.
It was mostly meant to be an analysis of the damage around that area, and so far, it doesn't look too bad. I'll check out the upper framework behind the subframe, but this looks hopeful.
Here's the hole again, not cleaned up yet. I see many cans of weld-thru primer in the future. Note the unusual rust-free lower-wing-sill-amalgamation-area:
2603416
Hopefully, I will be welding in patches soon. The driver's side floor pan is still on its way, and I have yet to pick up some suitable scrap metal to make the smaller stuff. When I have everything lying in front of me, that's when I will probably start messing with the welder.
That's all for now, I guarantee more updates on poor old Rusty will come (unfortunately?).
Discussion Starter #48
Something big has arrived in the mail. It might just be a Klokkerholm floor pan.
Once I have everything planned out, I will drain the fuel tank and get the left side of the body sealed.
2603788
2603789
2603790
I hope you enjoyed massive pictures of wrinkled sheet metal.
On another note, I ordered a set of window scrapers from EBAY ( > $ ), and they showed up just now. The old scrapers were rotting apart, so the removal of those metal clips required the use of fire to separate the metal from the rubber and rust. I guess the heat may have also tempered the clips. Trivial...
Should I be using weld-thru primer on the areas I am gonna spot-weld? Will any weld-thru primer work for this?
Discussion Starter #49
"Like a Hot Knife Through Butter"
I have made some major progress this past week. I've gone through 2 cut-off wheels.
No welding yet, but, weather-permitting, I should have the most of the driver's side floor in place. I still need to get weld-thru primer (industrial supply stores either don't have it or are closed) and a few other things, but it is gonna happen.
*Probably won't.
On Friday, the first thing we did was cut up the Klokkerholm floor panel to test for fitment and placement.
2605255
2605256
As I noticed earlier, it is not of the highest quality, but I really don't care. It fits roughly enough that it should work, and that's really all I care about.
Note that I have a fiberglass welding blanket hanging over the windshield. If anyone out there is going to be doing this to their car, make sure to cover ALL glass surfaces BEFORE grinding or welding (I found that out the hard way on another car).
Next up was to remove the cross-member running perpendicular to the sill. My pilot bit wore out before I could drill out the pilot holes for the spot weld cutter, so I just cut it out with the ol' wheel. Re-installation took a "cross that bridge when I get there" in my mind; again, I didn't care.
2605257
2605258
After that, I had access to the area where the frame member joins with the sill, and I tell you, it is a funny design.
The frame member bends up and meets alongside the inner sill, and gets sandwiched by a few spot welds. That, and the cross member above (err, not anymore...) helps to maintain the rigidity of the protruding frame member.
Before I started cutting out the rust (very challenging), I got the gut urge to place my jack underneath the frame member-sill-intersection point. A lot of metal is gone, and I want to keep the body as straight as possible. I cut underneath and around the "sandwiched" area mostly so I could keep my repair as clean as possible, no matter how ugly it looks as of right now. Should I worry too much if my Mercedes "Bends"?
2605260
2605261
I hope to have some of those spot welds drilled out and to have that bendy panel thing off of there some time this week. When I get the rest of the rusty metal cut off the floor transition, I will be in the clear to start welding.
On the topic of welding, I picked up some Lincoln Electric NR-211-MP FCAW wire from Lowe's today. I have been practicing with the standard HFT wire the welder came with, and am not too impressed. It is less about burn-through and more about just getting a clean bead.
If you see in some of the pictures, a metal sheet is visible covering up the fuel lines. I currently don't have a container large enough to store the nearly-full tank of fuel this car has, so I ended up following Nutz's earlier advice in depressurizing the fuel lines, at least as a precaution, as I am working around them.
Keep in mind that all of this, this whole project, is a learning experience for me. I don't know anybody who has ever welded on a car before, let alone an entire floor. I'm suddenly the local expert simply because I have to go through the whole learning curve to save this poor pitiful car. My apologies for the digression, I just wanted to be honest about my experiences here. And just so you all know, I have absolutely no intention of quitting on this car.
I think my favorite part of shopping at Lowe's is hearing the robotic intercom. "Special assistance needed..."
Discussion Starter #50
(Late) Wednesday's blog update, no pictures:
So, I just picked up some Pro Line EuroSpray copper weld-thru primer from the local autobody supply (they didn't have zinc primer in-store, but they special-ordered a can for us) to test out on my unfinished patch panels. That bent piece of metal seen in the last update has been cleanly removed, and I have enough metal cut out to start welding now. So, I guess my question is, now what?
I am planning to clean the WD-40 off the patch floor (it was a precaution when I stored it) and coat the edges of the patches with the primer. I plan to spray a little extra on the areas where there will be "spot" welds, just as a preventative measure. After that, I'll mark the positions where I want all the plug welds, drill the holes, cut out the weak metal on the outer door sill (I'll fix that with sheet steel from Hardware Sales), clamp it in place, tack the constituent panel to the sill, fill the plugs, work the bead around the piece, prime & wax the back welds, treat the outer welds, put the seats in, pull the engine, etc...
Everybody got that?
If I am wrong in my above order, and if there is a better way to do this, PLEASE speak up! That's the whole purpose this restoration "thread" was created.
All I need now is some weather I can safely go out and do stuff. Lately, weather patterns have been following the same basic routine for Fall: clear and 2 degrees Celsius, or pouring rain and 10 degrees Celsius. The weather is supposed to be nice(ish) tomorrow and Friday, so maybe I'll lug the welder out and get something done in the car by then.
The dashboard this car came with is very nice. It's not perfect, but it looks good. A couple imperfections it had that were driving me nuts were several small dents on the curved section behind the steering wheel. I figured out that I could actually iron these dents out using a model airplane heat shrink covering tool I had lying around. After I cranked the knob up to about 300 degrees Fahrenheit, I just worked it over the punctures (NOT SLIDING IT AROUND!), and they slowly disappeared. That is my contribution to the world for today.
I'm starting to notice all the W123s that live locally. Just today, I saw a pristine white 300TD wagon AND a brown 300D Turbo Diesel (no roof rack!). I'm getting inspired by them all...
Discussion Starter #51
(slight) Progress!
Oct. 15 Update:
I had some time to work on Rusty this weekend (finally!), and the weather wasn't bad. As of now, I am waiting for the weather to clear up so that I can tack the first patch in place.
When I first started working:
2607807
Area cleaned up a bit:
2607808
And the first patch panel fitted in place, ready for the next step:
2607809
2607810
When it warms up, I will coat the seam areas with some newly-acquired UPOL zinc weld-thru primer and move on. I still want to cut out some of the perforated metal on the outer door sill, to bolster the area around the patch. Again, I am eager to get on with this project, but stuff always seems to get in the way (weather).
When I went to Wesco to pick up the primer, I also got, at the recommendation of the staff there, a quart of something called Zero-Rust. They told me it was much like POR-15, only it cost less due to the elimination of the "brand-name tax". If it is able to be topcoated, I will probably not only apply it to the top of the floor, but maybe as a durable base for rubberized undercoating on the underbody. Has anyone actually used the stuff, or is it just some crummy marketing product?
Stuff is indeed starting to happen, just not at the rate I had expected before starting this project.
I hope to have the floor sealed by the end of the year, but we all know how that's gonna turn out...
Discussion Starter #52
Something came in the mail...
2610415
This posting is hardly useful to this continuity. This is only a "teaser" for things to come, that's how much has happened (or rather, what is going to happen).
Discussion Starter #53
November 18th Update:
Anyone still watching this project will see that I haven't updated this much lately. That doesn't mean that the restoration is idle, I've just been proceeding along while meticulously planning each next step, overthinking everything, and scheduling when I do things, mostly due to the foul Northwest weather. I've also been making a lot of connections with the local community.
Which is where I lead you to the BIG update, the one I am quite excited about!
Some of you may have already heard that I will finally be able to complete the rust repairs under a roof. Over the course of a year, I have convinced the instructor at my educational institution to allow me to use the shop room to do all the welding in the car, circumventing the rain outside. I'll probably bring the car over there on Monday morning, then drain and depressurize the fuel system, cover all the windows, and then spend a week forming and attaching panels with commercial-grade equipment.
The first step was to get the car somewhat mobile. I had the entire electrical loom disconnected in the center of the car, for easier access to the floor repairs. I reconnected that, twisted the rinky-dink fuel pump electrical wire together, reinstalled the steering wheel, and looked at the big hole in the floor. Everybody I have talked to about rusty floors has said I should just lay down a piece of plywood, so I humored the idea, telling myself that it was "just temporary".
Here's the tightly-fitting wooden framework constructed over the rust. It looks simple enough, but it involved quite a bit of measuring and adjustment to make it rigid enough. My signature handiwork:
2611524
2611525
While I couldn't do much to the body, due to the rain, I decided to fix the annoying issues with the grille assembly. Really, the only priority of this restoration is to work on as much as I can, therefore I do all this random stuff at random times, like the grille. By now, the whole thing was driving me crazy, with rust around the inside of the chrome frame, and the aluminum badge that had whose threaded shaft had stress-fractured somehow. I painted the inside of the grille housing with Rust-Killer, then experimentally, I dipped all the grille hardware in the stuff. The aluminum badge that holds the top of the plastic grille to the housing (that broke) was refitted by widening the slot on the plastic grille, and installing a flange nut backwards (with anti-seize this time). The thought of repainting the plastic inner grille occured to me, but I didn't have much grey primer in the correct original color. I didn't get any pictures of the grille, but the change did impress me.
More importantly, I also formed some patches for the driver's floor. I will leave this with some pictures of my attempts at panel-bending:
2611526
2611527
2611528
Discussion Starter #54
Rusty made it to the high school this evening problem-free, unsurprisingly. With one headlight. In the dark!
Tomorrow morning, we'll pull the car into the shop and get it ready for Monday (when the welding starts). That will entail masking off the windows to protect from iron filings, blowing all the internal crevices out with compressed air, draining the petrol, and some minor disassembly. Hopefully we'll be able to pull the fuel tank as well, and repair any rust underneath.
I just hope nobody touches the car overnight, as the educational institution is located in the near-center of a somewhat shady industrial park.
2611860
2611862
Discussion Starter #55
Nov. 26 Update:
Things are Starting to Heat Up!
My apologies for leaving this blog in the dark (ha?) like that.
On the cold, icy Friday morning, after leaving Rusty in the high school parking lot overnight, I brought the car into the shop. It's pretty interesting, once you understand the quirks with an old engine like this, you can get it to start practically every time, as it did for me.
2612164
Next, after everything was working nicely, I carefully maneuvered the car into the shop. It took a little bit of "manual adjustment" to get the car where we wanted it, along with a few trials and errors. We haven't had a project this big in our shop, so I am glad this got to happen. I'm also quite glad the space is heated during our cold and wet winter months.
2612165
2612166
2612167
We then proceeded to re-remove the front fenders, bumper, lights, and anything reducing access to the major rust. At the end of the day, we pulled both left-side doors off the car for better access still, though I fear there will be challenges in the reinstallation of the doors.. So far, we've been disconnecting the fuel system (futile?) and looking over the entire underbody to figure out how best we'll attack the major rust.Our (my) main priority is safety, so we are completing this project in the most strategic way possible. It looks like this is finally gonna happen!
I'll put up more pictures tomorrow if we finally get to the first welding by then.
2612172
Discussion Starter #57
Arcs and Sparks!
Update for December 17:
After spending a couple weeks thinking about what a bad idea this was, we were finally back on track to start welding. We drained all the gasoline/petrol out of the car, disconnected the fuel lines at the fuel distributor and severed them at the subframe (we're gonna replace them anyway), pulled the other two doors off, yanked all the wiring and vacuum lines out of the way, and cut out almost everything bad.
The car right before I left this evening. The facilities I currently have at my disposal really couldn't be better. It sure is a change from my gravel driveway!
2614301
As a bit of an experiment, we cut out the driver's side floor with a plasma cutter. I put my obsessive-compulsiveness to work on the right-side floor, drilling out spot welds and performing careful precision cuts for the patch panels to smoothly fit in place. Even now, I can still smell smoldering undercoating from the grinder. I'm glad we have fume extractors.
The (absence of the) driver's side floor, ugly edges and all, after seeing the plasma cutter. I don't know where the paper airplane came from.
2614311
The passenger's floor, right before we did the finishing touches on the inner rockers before finally buttoning it up.
2614312
And the first tacks in place for the passenger's side floor, MIG welded. This is just a rough fit, I'll do some trimming and rearranging tomorrow morning. I did not use any weld-thru primer on the edges or spot weld flanges, as we were pressed for time and just wanted it in. Nor did we cut and replace the lower outer door sill edge, for the same reason. But hey, at least this is progress.
2614313
Come tomorrow, I might get underneath the car and bolster the lower area, just for my reassurance. I'll also trim around the rusty front outer edge and maybe get that sealed as well.
All this work raises a few questions I have about the future rust resilience this car will have down the road.
1. Since I didn't apply weld-thru primer in some critical areas (pressure to have it done fast), should I be worried?
2. There was rust between the spot welds all the way up the back edge of the transmission tunnel, should I be worried? 3. We aren't reproducing the factory spot welds, should I be worried?
4. We didn't spray anything inside the door sill before we welded, should I be worried?
4. Are we doing this correctly? Is there a better way to handle these weld seams, from somebody with more experience?
5. And what is THE BEST way to seal up ALL of these repairs once they are completed, for MAXIMUM rust resistance?
All in all, I am quite happy with the work done we have been able to do to the car. Things are moving along well, and I hope to have the seats able to sit securely and solidly in place by mid January.
That's all for today and the past month, I do hope Rusty can be back on the road soon.
Discussion Starter #58
Happy 2020, people!
I hope it won"t be Y2K all over again.
Now, if I can only get stuff welded in this year...
2615481
Discussion Starter #59
Jan. 18 Update:
This update is not going to be much about progress, but more about the car's future, and me wrestling with my situation. And possibly gaining some new perspectives.
I left Rusty in the school's shop over the two-week mandatory holiday break after getting the passenger floor installed. Unfortunately for the project, several unseen setbacks have forced me to prepare the car to go back to the driveway. So, I left the car the day before the holidays with many things to think about. First of all, I had brought the car into the shop on the terms of it being more-or-less a "community" project for the "Aerospace Engineering" segment of the school's education. That is, something that students can come in and watch this happen, or help out. It was my hope that I would bring something wonderful to the school; a real-life repair in action that people could get an intimate look at, all in their own school. However, there were maturity complications involving several students, as well as poor planning on my part, that came together and collapsed the project. The school itself is fairly new, and has not had a project of this sheer magnitude undergone in its shop, and this may have been the trial run. So, naturally, there have been many unforeseen complications within the whole execution. However, things were not executed correctly, and lacking in the proper care and patience required for thorough, long-lasting repairs. Including, beware, unchecked untreated lap welds.
This whole idea was brought about by the fact that I have no proper location of my own to perform the full proper restoration this car certainly deserves. We theoretically have a garage, but only in the sense of a wooden box on our land. The thing is decrepit; unsafe, a public health hazard. It has been standing in dirt and clay for 90 years, on a property with absolutely no water management whatsoever. Therefore, it is toast. We have plans to rip it down and build a prefabricated steel garage in a similar footprint (12'x22'x7'). The problem of that is our financial situation, and my limits. I won't go into much detail about that, but I'll admit that I am a seventeen-year-old (as of now) certainly somewhere on the autism spectrum. A change from the last decade of our life, we now have a modest income, but are still struggling with debt and maintenance of neglected facilities. Oh, and food.
Then this car fell into my life, and I fell in love. Well, I keep hearing how love can drive people to insanity, and I am wondering if I've already crossed the threshold. This car has consumed the last 1.5 years of my life with its unending charm and deep mysteries. It is what I wake up thinking about, and it is what I fall asleep thinking about. This car is my one escape from climate change, from evil politicians, from the impending doom of humanity. And now, I am starting to wonder. Was it really all worth it? I mean, sure, some may say that I have gained much experience and "wisdom" from this project, but can I go any further? I had massive dreams for this car, none the least of which was getting the unit body solid again. I wanted to preserve a piece of extraordinary engineering that I marvel at and respect. And also save a bit of history, so that humanity can remember the time it thought of and tried building a car that would last forever. Sure, it obviously didn't last forever, but the idea of fine engineering will surely live on to inspire others. The pure experience of driving this car, even in its undignifying condition, will be enough to have made an impact that will survive until the last steering wheel of my days, be that flying-electric-antimatter-spaceship-car-steering wheel, has to be pried from my sore, blistered hands. And that's the truth.
But still, there's a part of me that is telling me to give it up. Many people, too. One of the first things I hear when people come over to marvel at how beautiful the car is, then seeing the floors, is that I shouldn't waste my time on a rust bucket and that it would be easier (there's that word again) to part the car out or sell it as a whole "parts-car" and get a couple hundred for it. And, despite what I've said before, I am genuinely wondering if I should.
But I simply cannot. This car is too beautiful to just wash my hands of. I know it isn't the so-called, "financially-wise" decision, but is that really what I should be working around? Should I junk Rusty, pay for a garage, and buy another W123? Or should I keep going, relying on favors and hopes to accomplish my "financially-unwise" dream?
2616239
All right, I am done. Please give your thoughts and wisdom. Oh, and by the way, do I have too many images inserted on this page? I have been experiencing loading problems, and want to know if anybody else does as well.
Discussion Starter #60
Feb. 14, 2020 Update:
The Voyage Home
2620631
To my great relief, the stars aligned and we were finally able to bring Rusty back home. Even in its sad, decrepit state, the car was able to move under its own power (although it hurt to do so). We crammed the car into the remains of what was once a garage, and threw a tarp over the car, as the garage has many "drain" holes through its roof.. Now that we are entering the rainy season, I want the car protected from constant degradation.
2620632
2620633
We have had some relatively clear weather lately, so I have had the chance to get a bit done. Now that I don't have the burden of time on me, I have decided to go with a total stripdown of the interior, suspension, driveline, and everything else. I won't be pulling the engine any time before the summer, as we are likely to have to move the car out once more, preferably on a flatbed, as a temporary rental garage space is looking increasingly attractive and may be in Rusty's close future. Therefore, I am not tearing the whole car apart quite yet, but I am working on little things as time allows.
2620634
So far, I have much of the wiring harness disconnected, as I plan to pull the whole thing for reasons nobody else would understand. My ONE complaint with the W123 is how the wiring loom must be removed as a whole unit, and it is not a very elegant installation in the first place. Since I also have a significant amount of rust up over the parking brake pedal assembly, that is going to be moved aside as well. Next, I am going to see what I can do about the hood hinges, as propping the heavy hood up (limited space overhead) with a stick has proven to be quite dangerous for me. Someday in the (distant) future, I would eventually like to get the hood itself stripped and properly repainted. Any idea what a single-panel paint job would cost?
2620635
Other than that, I don't have anything else to say. Most of my time lately has been usurped by Rusty's new friend (nemesis?), Hans, a beautiful 1987 300E.
2620636
More coming on Rusty eventually, you will probably hear Hans' story sometime soon in the W124 section.
-END TRANSMISSION-
41 - 60 of 70 Posts
